Let's see those home screens!
Pure Red Theme for ADW Launcher by Vision Mobility
Lock screen using Widget Locker
Great job, they look fantastic. Can you share what the clock is in the first screenshot and which icons are used in the second screenshot? thank you
http://forum.xda-developers.com/showthread.php?t=1245662 link for my homescreen icons I use a mixture of all his updates.
http://forum.xda-developers.com/showthread.php?p=18878748 link for the dot clock mclock I had to go through and change the orientation because on the one I downloaded it was set for left. Not sure if they all are like that.
Reactions: dollface
[Icon/Theme]Illest Icon Set v1.2[Miui Theme v2][mClock][New Phone Setv1][11/23/11] - xda-developers link for my homescreen icons I use a mixture of all his updates.
[MOD][GUIDE] mClock Skins | Updated 22 Dec - Page 84 - xda-developers link for the dot clock mclock I had to go through and change the orientation because on the one I downloaded it was set for left. Not sure if they all are like that.
Thank you so much, no wonder I liked those icons, I already have the Illest set. :-!
I also changed the orientation to Center as well, most mclock skins are set for center. Probably the creator just liked it on the left.
York's Black Theme for ADW with Dot Clock skin for mclock
Lockscreen skin for Widget Locker by Vision Mobility, available at themesinmotion.com, also using Missed It and Berry Weather widgets
^^ thats actually Fancy Widgets set at 4x2, Im very happy with it. there are many clock and weather skins to choose from, I switch up quite frequently, my wife laughs at me I switch the skins so often. heres my most recent one since adding the ADW launcher, I love how you determine how many dock icons you want, and you can size them to your liking
Yes, I own Fancy Widgets as well. Thank you!
mama baer
