LG G2: Disabling AT&T Address Book
just did it simple and worked the first time how do you people figure these things out thanks for the info
It takes you to a menu to select what your current registration status is for the address book. It worked just like he said. You're right to be concerned, so I thought I'd just confirm that it does work, since you obviously came here for a solution. Haven't seen the screen to sync the address book since.
Hi friends,
Did you noticed that the At&t address book again activated and the previous code doesn't work. Please help to remove it again.
Might you have a way to disable the annoying AT&T message I get when I go into texting about their backup & sync?
THANK YOU!
New sim re-triggered that. Your post was just what I needed!
I have spent almost three days finding out solution. This is really worked, no need to root.
"Here how to disable the AT&T address Book: Go to dailer than dail *#*#2666#*#* and setting "registration" to "completed". Exit out than you are done."
Wow, totally worked on this G5. Thanks so much for such a simple solution to annoying bloatware 😀
lphilpot
