LG G3 Cases
The new otterbox is a treat....So slim..
Sent from my LGLS990 using Xparent BlueTapatalk 2
Passing by an AT&T store in Orlando Florida I decided to stop and check for LG wireless charging circle cases. They had one left. The Powermat device cost me $50 and the circle case came in at $59. A quick judgement is that the back which replaces the stock back cover is equally sturdy although the front flip cover is extremely thin and light. If you value real protection I would consider something else but this combo wirelessly looks cool IMO and seems to charge no problem.
wish the texture was leather like Sparker04's
Is the circle case the only way to get wireless charging on the US-versions of the G3 or are back plates available that will fit other cases?
Just received my Cruzerlite "Bugdroid" case. Fits like a glove. Will still probably get the Ringke later.
Take the sticker off your volume button! Nice case, bought the same one myself...arrives tomorrow. :)
My gf almost took it off last night but I told her not to because I want to hold on to a piece of newness of my device, lolol!! You picked a great case! Enjoy! :)
The tech21 tactical for the LG G3 will also be at Best Buy in stores starting Aug.3 at least that is what it says on their website
I had the Supcase Unicorn Beetle on my M8 and I loved it. Just got one today for my G3 and it looks great, but makes the width just a hair too thick for me. I also got a cheap plastic snap on case that keeps the width manageable with one hand, so I'll probably stick with that. Does anybody know if any company makes a frosted or smoke hard plastic slim snap case? That would be ideal...
tech21 for the LG G3 will be in stores at Best Buy on Aug. 3 according to their website, impact tactical only not the impact mesh
Too late couldn't cancel my order from tech 21 directly. Got the impact tactical.
I have diztronic case from Amazon. Fit great lightweight with full protection. Also Verizon had tempered glass screen protector for 18 after discount. Best looking screen protector I've ever had.
http://www.amazon.co.uk/gp/product/B00HS5LRC0
I brought this case in a hurry, wanted something not to big and simple. Really shows off the phone and comes with a screen protector, which is pretty poor as seen in the photo, but that'll get you started. (£9) the notches on the corners let you see how thin the bezel actually is which is nice and makes the case flexible so you can the phone out easily.
QI charging works through the case, thankfully as I brought a ravpower 2-in-1 backup battery/wireless charger. £35 pounds also on amazon - that I would definately recommend (4800mAh) compared to the G3s 3000 and will keep you going for 2-3 days with moderate-heavy use. Also think it has an auto shut off of the coil when its fully charged.
first time blog, hope it helps
Here are some pictures I took last night of my Spigen Ultra Fit and Slim Armor cases in the mint color. They aren't the best pictures, but they will do.
Ultra Fit:
Slim Armor:
I was really unsure about the mint color when I ordered it, but now that I see it I am really fond of it. It is a really nice mint color and isn't too 'Tiffany Blue' bright.
As far as the cases go, I really like the Ultra Fit because you can see the mint from the front view of the phone. There is a small lip the keeps the screen from getting scratched if you put it face down, and a bit of a lip behind the charging jack to give the bottom a little more protection.
The Slim Armor fits around the entire device and provides more protection. It fits perfectly and provides more of a lip for the screen. The only downside for me personally is that I can only see the mint from the sides/back.
Looks sharp xPNUTx! I ordered the Spigen Slim Armor in Metal Slate last night and I'm very excited to pair it with my white LG G3! I also have the original screen protector on like you do while I wait for my screen protectors to be delivered.
Yeah, I hadn't even turned the phone on when I took these pictures, lol. I took them with my Note 3 and then activated the G3 :D
Going camping this weekend so i needed a case quick. Picked up an incipio and a body guardz glass screen protector...
Sent from my LG-D851 using Tapatalk
cmdouna
