Lg G4 Double tap and glance view not working.
Stylazation
Active member
Oct 15, 2014
30
As the topic says, the glance view and double tap stopped working after shutting down there phone and leaving it in charge. Turned back on noticed that some features like glance view, double tap to wake up, vibrate on tap wouldn't work. Fixes vibrate on tap by turning off and on again, recalibrated phone still the glance view and double tap to wake up isn't working with screen time out being 1 minute and it dims and turns off in seconds.
Any one know this problem or a fix may be. Kindly put your effort and thoughts I to the topic thank you.
Or do you use an launcher different from LGs launcher? If so did it get an update?
Fix
1. Download this app
https://forums.androidcentral.com/e....sika524.android.quickshortcut&token=VxGdGxGK
2. Open app and select normal search
3. Search with keywork "knock" and add that shortcut.
attachment.php
Then open that shortcut and make sure that knock on is turned on.
Did your phone update on you? Sometimes an update will change settings.
Yes, the while phone changed settings most of the features turned on were turned off. It felt like being on stock. But I did not accept it allow any update on my smartphone. That's weird really.
Johno
