gendo667
Trusted Member
- Jun 6, 2015
- 4,730
- 1,840
- 113
Hey! so i own a G4 505 as well and i'm stuck with the same problem more or less. my phone initially just stopped working out of the blue. At first the phone would get at the start screen with the lg logo but now that's not even there. Its completely gone! Plus my phone is not under warranty.
My photos and other documents are on it and i had not put in my sd card thinking that it has ample space but i clearly shouldn't have done that.
Will putting in the freezer do any good?
Couldn't hurt. I'm not sure you can backup to the cloud from a freezer. If you have an SD card I'd try that out first. I haven't heard if any G4's getting water damage from the moisture or anything like that, you should be fine.
