GrooveRite
- Sep 30, 2010
- 3,530
- 122
- 63
The two reasons I will not go with the G4 are the embedded battery and non-expandable memory.
Huh?!? The G4 DOES comes with removable battery AND SD card slot.....just so you know.
The two reasons I will not go with the G4 are the embedded battery and non-expandable memory. In my book, this makes the G3 a better long term device.
Lg produces fine products. I've never had a problem with their phones. I currently have an S4, nothing but issues from the beginning. Once the G4 comes out, I will be getting the G3 at discount. The two reasons I will not go with the G4 are the embedded battery and non-expandable memory. In my book, this makes the G3 a better long term device.
I believe you're getting the S6 / G4 confused. The S6 has no SD-Slot and an embedded battery -- The G4 is the opposite with a SD-Card Slot and also a removable battery.
