LG L45C (Optimus Net)
Hey your LGL45C is rooted? I've tried literally over six ways but none of them work. Tried unlockroot.com, but program didn't work. Could you suggest something?
Root LG Optimus Net (LGL45C) - Solved
*Must Have at least a 4GB SD Card in phone.
From PC:
*Format the SD Card in PC.
(I use MiNi Tool Partition Professional to format - Install on PC)
*Use PC Card Reader for SD Card.
*Format 80% for Fat32/Primary/Active
*Create the remaining space for EXT2//Primary.
*Install (Copy) to Root of SD Card:
*SuperSU
*Root Check Pro
*Link2SD
[Guide] partition and link2sd [pictures included for each step]
[Guide] partition and link2sd [pictures included for each step] - xda-developers
Credit and Thanks to *sanny5*
From Phone:
1) Factory Reset
2) Skip /Google Sign In
3) Go To /Setings/Applications
4) Click /Unknown Sources /On
5) USB Cable To PC - Phone On
6) Run /UnlockRoot Pro (Buy it and Install it on PC)
7) Wait For Device
8) Run /Unroot (to be sure device is not rooted)
9) Run /Root
10) Wait till Complete
*ReBoot Phone (Disconnect USB Cable)
11) Run Root Check Pro - Check for root and Busy Box
12) Run SuperSU
13) Run Link2SD - (go to Settings - Click to Auto Move)
ENJOY!!
Re: Root LG Optimus Net (LGL45C) - Solved
I used sons of korhal to root the lg l45c, no problems. RootChecker says yeah.
I can't seem to get link2sd to work. When I start it, it says
"unable to create mount script". I read that some phones don't support ext2/3/4, (i tried formatting the l2sd partition
to all those), so my l2sd partition is fat32. Still, the same message. Dx_roid, any tricks you needed to link2sd working
on your l45c?
Thank you
on your l45c?
Thank you
Hi jbh3,
Are you positive you created your SD Card as follows:
From PC:
*Create 2GB for Fat32/Primary.
*Create the remaining space for EXT2 or EXT4/Primary.
Install (Copy) to SD Card:
*SuperSU
*Root Check Pro
*Link2SD
I did not do that exactly, but I will. I used Mini Tool Partition Wizard while the 4G sd card was in the phone.
But I'll follow your procedure & report back. One question though... how do I copy apps (SuperSU, Root Check Pro, Link2SD) ?
I get them from google play, I'm not sure how to get them to my pc to then copy them to the sd card.
Thanks again!
Thanks again!
That's easy.
*Download the 3 app's to a folder in your PC.
*Since you have formatted the SD Card in the PC, and after you shut down Mini Tool,
*Copy the 3 app's to the 1st partition of the SD Card.
*Remove the SD Card from your PC,
*Insert the SD Card into your phone,
*Boot your phone.
Go Here to Root
From Phone:
1) Factory Reset
7) Wait For Device
9) Run /Root
Go Here if Rooted
From Phone:
11) Run Root Check Pro - Check for Root and Busy Box
12) Run/Allow SuperSU
13) Run Link2SD - (go to Settings - Check: Auto Move to SD Card)
*Link2SD: You need to tell Link2sd where to move files: Check EXT4
Hi Dx_roid,
Thanks for your help. I'm afraid I'm stuck at the same spot though. Some
Things that are better... I had not installed busbox on this phone, I think that's
a must have. SuperSU recognizes busybox and Link2SD, and remembers that
I've granted them permission. A thought.. SuperUser is still installed (it came
with the korhol root). Maybe I should remove it? I think SuperUser and SuperSU
do the same function.
I tried formatting my partition (2G for l2sd, 30G for the rest) in ext2 and ext4... same message:
Mount script error
Mound script cannot be created.
mount: Invalid argument
Any suggestions?
Thanks for your time
Hi Dx_roid,
Mount script error
Any suggestions?
Only one SU should be in your phone.
Remove SuperUser.
I suggest this one:This is the Free version
Code:
https://play.google.com/store/apps/details?id=eu.chainfire.supersu
This is the Paid version ($2.49):
Code:
https://play.google.com/store/apps/details?id=eu.chainfire.supersu.pro
But, I don't think this will solve your problem.
Link2SD needs to be know where to move new app's to.
That's the problem.
Either your SD Card is not created correctly; or your phone is not configured correctly.
wobblefix
