LG Nexus 4 won't use data plan for applications
scolari9
14
Okay guys, I hope you can help me, I really can't find a solution to this problem. My Nexus 4 somehow won't use the data plan I get from my service provider, for example, when I launch Facebook application when I have providers internet connection, it just says "No internet connection", but if I use Chrome everything works just fine. And it's like that for all applications. But if i connect to wifi all applications work normally. What could cause this problem and how to solve it? I hope someone knows.
Regrads
Which provider are you using, and have you configured the APN settings for your provider?
I use Tusmobil, you probably never heard of it haha. Well I configured my APN settings for MMS and Internet. I use the following settings:
Internet:
APN: internet.tusmobil.si
Proxy: / (not set)
Port: / (not set)
Username: tusmobil
Passw: internet
server: / (not set)
MMSC: / (not set)
MMS proxy: / (not set)
MMS port: / (not set)
MCC: 293
MNC: 70
Vrsta potrjevanja: PAP
APN type: internet
MMS:
APN: mms.tusmobil.si
Proxy: / (not set)
Port: / (not set)
Username: tusmobil
Passw: mms
server: / (not set)
MMSC: http://mms.tusmobil.si:8002
MMS proxy: 91.185.221.85
MMS port: 8080
MCC: 293
MNC: 70
APN type: mms
Do you see any mistakes? Or what could be wrong?
You're right, never heard of them :)
I can't read Slovenian, but the APN settings listed on the tusmobil website have a different username:
Tu
It might be worth giving them a try.
Yeah, sorry I didn't see some of words were in Slovenian. But I've solved the problem before, and the APN settings on their website somehow didn't work for me (tried it before). I got some different settings and it works fine now. Thanks for your time.
liquidsnake757
