LG Optimus S: 4.4 KitKat?
Re: 4.4 KitKat?
I'm curious does thekraven's cwm recovery format anyone else's sd-ext correctly? For me it fails
Re: 4.4 KitKat?
Same here. I heard about this happening with other cwms. I think there's a way to build it that gives an option to use rm -r instead of makef4fs. Is makef4fs even the right command to format ext4?
Re: 4.4 KitKat?
TheKraven, since your cwm build Is required to flash cm11 would you oppose to having it posted in the OP of skinbarks thread?
Re: 4.4 KitKat?
No, still under review I think. You'd better check your files before you build.
ah, it's under review all right... what I didn't notice was that they removed the commit rather than adding it. I'll fix it myself the way they said until they approve it.
Re: 4.4 KitKat?
Yeah no problem, The latest recovery.img will get built every time you build cm11.
Re: 4.4 KitKat?
Try this wifi fix in our init.qcom.rc
Gerrit Code Review
Whee!
Working wifi!
Code:
on property:init.svc.ril-daemon=running
    start get_macaddrs
#on property:gsm.version.baseband=V07u-000-000-MAR-23-2009
   start setapversion
this stuff, I disabled the GSM bit, and made it start the service regardless, but it didn't start the ril.
/system/bin/get_macaddrs isn't being built and may help with bluetooth.
otherwise, the wifi fixes seem good. pinging Google.com in terminal works. haven't checked out the market yet.
View attachment init.qcom.rc.zip
Re: 4.4 KitKat?
Whee!
Working wifi!
Code:
    start get_macaddrs
   start setapversion
Glad it worked. I'd rearrange this one line like their's also and put it ahead that fix.
on property:init.svc.wpa_supplicant=stopped
stop dhcpcd_wlan0
And that last line you commented out is just for the gsm baseband reading. You still need to add a Settings patch for cdma. https://github.com/TheJBC/android_p...mmit/186aef97578bbb50a8f198ac2511bd229a630f9a
Re: 4.4 KitKat?
i had radio working on my early builds. If i have time i'll upload what i have later.
Re: 4.4 KitKat?
Make sure the vendor lge is just like this when you do a build. This should fix the ril on zvd. https://github.com/TheJBC/android_v...3f2d1e6e59e/thunderc/thunderc-vendor-blobs.mk
But you can just copy these two files from my build place the rild in system/bin with permission 0755, and the libril.so in system/lib with permissions 0644. It's not flashable, just extract and place in the rom zip.
Re: 4.4 KitKat?
I added these files and rild is not crashing. The phone number etc. is showing up in Settings > About phone > Status so I think it worked. Thanks a bunch kraven!
VascoPJ1377
