LG Optimus V Call Audio Drop
JHAT
9
Hey guys, I have a rooted LG optimus V on the latest stable CM7 build.
I'm having some troubles regarding calling. I'm not sure if this is the rom's fault or something I installed but whenever I call voicemail, it will just say "Please enter your passcode and pre---", and the voice cuts off. Same thing happens when someone calls me or I call someone else, the call lasts for 2 seconds and then the other side hangs up, but my call timer on my phone keeps going.
Does anyone know about this problem?
I am having the same problem. Incoming calls just stopped working completely as of this morning. And any outgoing calls I make last for 5-10 seconds and then are summarily cut off. My counter doesn't even continue counting...the call is automatically disconnected.
I am using the Harmonia edify ROM with the xionia kernel to fix the blank screen issue on the newer Optimus V. I rooted with Gingerbreak. My wife has a stock, un-rooted optimus V phone and has been having the same problem. I will call Virgin Mobile and see if they have any insight.
Anyone else having this problem?
I made a call somewhere this afternoon and it also cuts off within a few seconds.
I am using BobZhome CM7 (not running the latest version).
Nationwide outage call them and get your minutes back.
Sent from my VM670 using Tapatalk
