LG Thrive Root, Customize, and Maximize Local Storage Memory
According to this page:
4. If trouble with receiving MMS, you can check ?Settings?>MMS Settings? first. And please don?t remove stock SMS app if you have MMS issues.
25. The relationship between GO SMS Pro and stock sms: It?s better to keep stock SMS. GO SMS Pro works well with stock sms. If uninstalled, there may be some problems with MMS sending or receiving. So it would be better to keep stock SMS for now.
Apparently, many people have issues with the way Go SMS handles MMS. They're not actually sent as MMS, they're sent as SMS & the recipient gets a link to a Chinese website where the picture is stored. Some have voiced privacy concerns, others can't get it to work right regardless.
Just wanted to chime in here and say thanks to you guys...I stumbled upon here via a google search and this thread was PERFECT....once again thanks you guys...
Reactions: LifesGoodPhoenix
Hey my internal memory is filling up and I uninstalled several apps and moved all that I could to my sd card. What is the remedy? I am searching!
Sent from my LG-P506 using Android Central Forums
I had the same issue, until I found Link2SD!!! :cool:
Now, I have 600 installed Apps and 100 MB free!!!
i was able to root my lg thrive & it had been working great. i was trying to do a bit more customizing & whatever i did, it caused me to lose the 1st two icons on the bottom bar, the phone icon & the address book icon. i don't see them anywhere, even when you press the center square that brings up all the att stuff ... :(
anyone know how i can get them back??
Uninstall the launcher or whatever app you used to try and "customize" your phone would be my suggestion.
If you used a program to remove files from your phone there is a good chance you removed parts of the apps you needed restore that program/file and it should go back to normal
Loki Samhain
