LG V10 OEM Wireless Charging Back in today -- Pics Inside
Re: LG V10 OEM Wireless Charging Back in today..............A few pictures.
I used to have a Note 4 in the zerolemon battery case, this is definitely smaller. I hope it works, I've been relunctant to buy one because of the uncertainty. Thank you so much. I appreciate it!!
OK, It charges just fine with the Defender case on. I'm using the LG OEM charging back with the TYLT VU wireless charger. I also tried it on the TYLT SOLO and Samsung "Fast Charge" wireless pads and it charges just fine with the fat Defender case on.
These are my personal results, your mileage may vary. :-\
Thank you so much!! I greatly appreciate the update
Great to learn, i captured some wireless efficiency's pictures from amazon, very similar with LG OEM.
seems to be several 3rd party items listed on Amazon. I wish LG would hurry up and release the OEM officially
Looks nice as it is just like OEM. But definitely not worth $80. I don't go to Starbucks that much which is the only place I have see with wireless charging. Plus I have the extra battery from the Promo. I'd pay about $10-15 for wireless charging.
Has anybody seen one with any color but black? I bought the blue AT&T variant and really don't want a black back on it. That would look really strange. LOL
What charging pads are you folks using for wireless charging?
TYLT VU and SOLO. I have the Samsung Fast wireless charger that I use for the Note 5 that works fine.
Will the TYLT VU or SOLO fast charge the V10? Which one do you like the best?
Nope, even the Samsung "Fast Charge" wireless charger charges the V10 slooooooooow. :-\
The V10 it's self is not capable of wireless fast charging.
I like the VU the best for the V10 but it's not fast.
I bought $12 back off of Amazon because it had Prime shipping.
The pictures make it look like the stock back, but it was all plastic and not rubberized. That might be okay, but I don't run a case.
I put it on and placed it on my charger and it kept switching from charging to discharging.
It's going back today.
which brand? yootech? i ordered it then cancelled, figured I'd wait until the OEM is official
I purchased the wireless charging receiver (yootech) it's been working perfect with Verizons 3 coil charger. :)
Tylt vu with a yootech wireless back.... Working pretty good for me
I purchased the OEM Qi back and OEM bumper from S. Korea. I should have them in about a week. I will update when I receive them. Can't wait
Will wireless charging work if you have a case on the V10?
In other words the case will be between the charging pad & the wireless receiver. Will wireless charging be hindered?
Any link to that shop?
My wireless charging works fine with the two thin cases I have. Have seen one poster saying it worked with thicker cases. I am sure there may be a case that is too thick.
Thanks, good to know.
I have read on the website of some wireless chargers that the maximum distance between the pad and the wireless receiver is 5 millimetres.
So I think that the sum of the case and battery back should not exceed that.
s1atoshi
