LGH815 (LG G4) power button and proximity sensor
Deepcuts
47
Hello,
I have an LG G4 since December 2015 and like many people I found out that "Double tap" to wake the device does not always work.
So, I ditched this feature and used only the power button to wake the device.
The problem is that even the power button does not always wake the device, many times, a second push being needed to successfully wake the phone.
I even called LG support and scheduled a visit to the service center.
Today I think I found the reason why the power button does not always work, at least for my device.
I usually leave my G4 with the front facing down, on the desk.
When I hear a notification alert or the phone rings, I grab the phone and press the power button while it is still facing down on the desk.
Many times in this situation the phone will not wake up.
So I started thinking it has something to do with the proximity sensor.
To test this, I covered the whole top of the phone (front side) with my palm and pressed the power button. No matter how many times I would press it, the phone will not wake up. At this moment, I will start distancing my palm from the phone while pressing the button every second.
Only after the palm is at a considerable distance from the proximity sensor would the phone wake up.
I thought about a feature in Android "prevent accidental wake up" but Marshmellow does not have this feature or I could not find it in Settings.
I tried searching the web for other G4 users having the same problem, but found none. Found a couple of posts about the button being defective and a couple of posts about screen protector causing the screen to not wake up after a call or interfering with taps on screen.
So the question is: It is normal for the phone to NOT wake up using the power button if the proximity sensors detects something close to the phone, like the surface of the desk?
I could understand "Double tap" not working while proximity sensor detects something and that is why I am not using that feature anymore, but power button?
It is working as intended? It is only my device?
Thank you.
It is working as intended. If it didn't work this way, the phone could constantly be turned on in your pocket.
Yeah mine is like that also. Pretty sure it's a feature to prevent accidental wakeups
It is the same with double tap too, if somehow the prox sensor is covered then double tap won't wake up phone. I also found double tap doesn't always work, but I am now used to tap until wake up. Usually it takes 4 or less taps. I only use the power button to reboot.
I assure you, this was not the case prior to the update to Marshmallow. The power button and volume buttons would still work when the proximity sensor was covered. Eg I could snooze my alarm pressing the volume down button when my G4 was facing down (ie the proximity sensor was covered). After the update this does not work anymore, annoys the hell out of me. Been looking on the internet for more posts about this, but yours is one of the few. I'll contact LG about this and post any updates here.
aduba
