Liberty Gingerbread
Hey Guys I'm Back! I learned a heck of lot these past weeks! I got my Droid X up and running about 3 weeks ago. Thanks for the help and your support going back to liberty this week after school lets out and then I will have a little more time to dig into the Droid X!
Welcome back. Glad to hear you're enjoying it lol.
Sent from my DROIDX using Tapatalk
Hey in Liberty what is a mirror? I'm installing Liberty Gingerbread Full install do I need to install that mirror also? I guess after that can I install v0.3 from there also??
If you are taking about "download mirror" that just means another download site for the file.
The mirrors are alternate download links. If you turn on wi-fi annd install the toolbox file you shouldnt have any issues(wifi is faster than 3g for me on downloads). Once you have 2.0.1 installed you can start installing the latest leak which I believe is .4 which comes with .591 kernel.
I haven't made any changes or upgrades in a while but suddenly yesterday and still ongoing, I cannot receive MMS messages. I can send pictures and small files fine but no one's pictures or mp3 snippets are getting to my device. I'm using Handcent and have the stock frozen so to avoid dual alerts. I unfroze it just to check and no change so this may be a Handcent issue. Did anyone else have that issue in Liberty? Or GB overall?
Yeah, I was having this same issue running Liberty GB .591 and Handcent. I had the stock messenger frozen and couldn't receive pictures. I had to unfreeze it and reboot. Everything is working fine. You can go into you stock messenger app, click setting, notifications and uncheck the notifications to stop receiving dual alerts. Hope that helps!
No the dual alerts always happen no matter what I do except freezing and sometimes un-installing the stock messenger app. That isnt a solution for me but ty for the attempt. I wish it were that easy but as soon as I re-up the stock app its gona go dual alerts on me and I cant stand that
Try smsGO. I like it much more than handcent. My gf has been having lots of problems with handcent lately on her OG droid.
smsGo is the only 3rd party message app I have used. Actually the only one besides stock.
I dont get double notifications with it along as i have unchecked the notifications alert on the stock app
sent using TaPaTaLk
Flashed from 0.1 to 0.5 this morning and it's beautiful.
Better in my opinion than .595 by a long shot.
Why/How is it better? The last liberty I ran was .4 and went back to .595 because netflix wouldn't work with liberty. Anyone got it going on V.5?
I'm on LGB v0.7 right now and I love it.
I'm currently experiencing 2 problems with it right now.
1. Gallery 3D sucks and it's extremely slow, so you have a choice to use the Blur Gallery
and if you do you can't share any photos from the gallery. It says no application found or something along
those lines. The Gallery 3D will allow you to share your photos, just not the Blur version.
2. With the newest update to v0.7 the Pulldown Text Editor doesn't stick with any text changes that have
been made. Like for example if you change it to "Verizon Wireless" it will change it to that upon reboot, but
if you reboot again for any reason afterwards it reverts back to Liberty GB v0.7. I've tried everything, even
manually editing the build.prop file and it does the same thing.
Anyone else having these same issues?
Hmmmmm does media share effect this if it's turned off via customizer
It is but doesn't change anything, but I tried.
Well, it's was a good thought and it would make sense. Thanks for trying :)
I'm probably gonna start using ZombieStomped until LGB is a more stable release
without all these bugs.
sukarisw09
