[LINK] [ROM] CM7 for Thunderbolt. RC1.2 Updated 7-6 11:59PM
Need flash 10.2 to watch flash. Netflix has a slight hickup for video. Signal handoff is bad sometimes resulting in no data. Going to 3g only brings it back, then you can put it back in 4g. Can't get any other keyboards working but stock is nice. Maybe just me? Solutions, feedback?
Other than that... AMAZING.
Sent from the Bolt via Tapatalk
I had to get a flash 10.2 from 'another' source for it to work but it does, just fine now... I just wish Nav was working better
I have not checked flash yet... that would be strange not having flash... but for keyboards, I loaded Swype's new BETA 3... you can go to beta.swype.com and register to get the keyboard... I have not tried SwiftKey X Beta (available in the Market), but I have to think that works.
****EDIT: Just downloaded Flash Player 10.3 from the market... nothing wrong with finding it or downloading it.
Reactions: SoDev
I have all those keyboards. Hmm, maybe a fresh install. When I go to language/keyboard it doesn't let me select them except for swype and then it doesn't input text when I try to use it.
You can watch flash video online with 10.3? Maybe I was lunching. I just googled flash 10.2apk, maybe that was an old issues that has been fixed.
Give me a page to check and I'll browse to it and see if I have any issues.
Got it flashed last night and I am happy runs a bit smother and I am not getting the ADW force close now and GPS locks in 3 sec... /sold
Reactions: SoDev
Ya, I'm getting sound but no picture... I see briefly a message about not optimized for mobile... I might check XDA Forums to see if there are known issues with this, but I don't have time right now.
I have noticed this too, I think there is a fix. I may have to look in to this today.
It is known. flash10.2 is the fix. Thanks for checking.
I got 10.3 to work... I found something on XDA using Terminal Emulator to change permissions: xda-developers - View Single Post - [ROM] CM7 for Thunderbolt. RC1.2 Updated 7-6 11:59PM to one file... I used Root Explorer to go into
/data/data/com.android.browser/app_plugins/com.adobe.flashplayer/.macromedia/Flash_Player
Long click on "config.data" file and change permission to 000, which is remove all Read, Write, Execute from Owner, Group and Others.
It worked with 10.3.
Reactions: SoDev
I get his far /data/data/com.android.browser but I don't have a app_plugins :confused:
This.
10.2 will give me the video but no sound, know I need two Bolts and use 10.3 for sound and 10.2 for the video :eek: I think I'll play around I'm sure I'm missing something.
This should make it more manageable. :D
thumb2.php
Still no plugin after reboot no deal breaker for me since I rarely use the flash player.
Sent from my ThunderBolt using Tapatalk
periyasamy
