[LINK TO] BAMF Sense 3.0 RC3 is LIVE
I downloaded from the mirror without any problem and it only took 12 minutes not to bad.
I've been so busy that I never got around to flashing RC1 so going straight to RC2 tonight. The das BAMF team is unbelievable!
I know its hard to keep up with all these updates but its sure is fun. I couldn't be happier with the Roms and developers the Thunderbolt has it makes this a great phone.
Sent from my ADR6400L using Tapatalk
I'm considering jumping to this. I know you have to flash a new radio with this, but I was wondering what radio to flash and where to get it. Also, what should I flash first, the radio or the Rom?
Sent from my Thunderbolt using Tapatalk
[Radio] [Leak] [6-16-11] MR2.5 Radio - 1.39.00.0528w, 0.01.69.0602w_1 - xda-developers
http://forum.xda-developers.com/showthread.php?t=1115714
Those are the threads for mr2 and mr2.5 radios, either of which will work with this rom or any GB Sense Roms currently available.
You want to check the md5 sum of the radio before you flash it, (make a nandroid backup in rom manager/or recovery), then you can flash the radio and rom in either order, but i would flash the radio (in hboot), let it settle in after reboot, delete the pg05img.zip file from your sd card at this point, then boot into recovery, wipe everything 2+ times, then flash the rom.
So, RC2 is pretty cool. Basically the same as rc1. I was going to return to 2.1 today but since this came out so quick i decided to stick it out for a while. Would love a rosie button remap mod in the future, and there is a transparant pull down bar at xda in the second or third post.
[Radio] [Leak] Official MR2 Radio 1.39.00.0508w, 0.01.69.0510w_3 - xda-developers
How do you check the md5 sum? Do I risk bricking my phone if I'm on gb? I know there were problems before. Sorry for being a pain!
you can use something like Astro File Manager (longpress the radio download file, properties, MD5Sum)
or
use an app called "HashDroid". open the app, "check file", navigate to the radio download file, select it, Calculate!,
then compare the MD5Sum string of characters shown to the MD5Sum shown from the download page
if they match--it's a good download
if they don't--it's a bad download. delete the file, download again in case it was a fluke. or download from another source (mirror site)
Reactions: zero neck
Day 2 on RC2 - Rom continues to be stable, carousel effect continues to be astounding, transparent pulldown patch is great, only thing i don't like is the inability so far to remap the rosie button.
Re: [LINK TO] BAMF Sense 3.0 RC2
All is working well but have a problem with my yahoo account.it is not updating. I'm using the stock mail app. I deleted the account and then added it again, whipped the cache, and nothing. Says I have "no mail". Any ideas? Thanks.
I cannot find a link that actually works for a radio appropriate for this RoM. Anyone know any links that are working for a good radio?
Wireless charging issue. Just got the pad and battery back. None work with any GB or Sense 3.0 ROM. Das Bamf Froyo works.
I havent ever tried a yahoo acct or had a problem with my gmail accts in htc mail..
you could try searching the rc2 thread linked in the op for mail syncing issues, maybe somebody found a fix.
Is it only me or does the camera seem less sharp
mine seems about the same as the other gb bamf roms, Maybe slightly less crisp than the froyo gb roms but could be my imagination.
sorry i've never used one of these ..
The links on both of those forums are having me wait and then I get an error =/
Agree, agree! Rosie mod would be nice. I also like the font change option in the tool kit. Also with this rom much better battery and seemingly no 3g lag, Pandora had lag between songs on preview 4.
hawkeyedigital
