Location Problem
p4ulm86
7
Whats up guys
i tried searching to make sure i am not double posting something but i found nothing similar to my issue
My nexus is stock nothing done to it and i have an issue with the Location services determined over 3G. it always gives me my past location and if i want it to make it work i have to reboot the phone.
For example if you use 4square or FB to check in ..it uses your location determined by network or Wifi.. When i have the WIFI on it works fine , however over 3g it doesnt refresh when i go from place to place.
My GPS works fine the only problem is the location services. i thought at one point it was the room i used before ( WHEN I HAD IT ROOTED) but when i installed MIUI rom the location services worked Good.. Any Ideas ??? thanks
I have that problem too. If you travel with the screen on it works "sometimes"
I use Settings Profiles to change settings based on location to correct the problem I created a rule that fires a free app called CellID Info that launches every 15 minutes when the screen is Off. Works pretty good, no battery drain
I have been having the same issue for a few months. Sprint insists nothing is wrong and refuses to do anything about it. I wish someone with more android knowledge could figure this out.
Bride96
