Location Unavailable Warning
Just did it again. FYI, there's 2 ways it notifies me and it's weird. First is the standard location error where it says it can't find the location and you need to turn on the features that improve location accuracy. This notification stays on the lock screen until I remove it. What it's doing now, is what it does a lot of, and that's send the notification and sound, but the notification on the lock screen disappears immediately. It'll do this a couple of times, or several times in a row. Then all of a sudden it does it and the notification stays. In the time I've typed this it's done it 3 times and now the notification is still up on the screen.
Does it show up in notifications panel ?
Go to settings >notifications >choose at bottom show all see the time under each app when it gave notification also while in there tap 3 dots upper right corner show system apps see there anything Google that pops up same time as it gives notifications turn it off
I actually think it may be my wifi calling. I have put the notifications on silent and to do not show on lock screen.
Yeah, when you look at frequency it stated that WiFi calling gave me an average of 8 notifications per day. That seems about right.
Can you try turning Wi-fi Calling off to see if the errors go away?
Also, are you using a VPN on your wi-fi network? If so, try turning that off.
No need to turn wificalling off but giving 8 notification a day that shouldn't can disable its notifications
I figured it's another way to identify the culprit, in case the OP might still want other notifications related to wi-fi (not sure what other notifications that particular service might give).
Rustybike
