I use Battery Widget Reborn. Lots of settings, gets the job done very nicely.Anybody know of any decent battery apps or widgets for Android 5. I've tried the app by kroegerama but it's very small to read and not sure if anybody has tried anything better
You can try it quickly and ask for a refund if it doesn't work the way you want it to. I believe you've got 15 minutes to decide. Not much time, but should be enough for what you need to make sure, IMO.Ok does that definitely work on Android 5 lock screen? I'll have to see if I can find some screenies before I buy. All others I've tried work when unlocked but not on the lock screen
It does. There's a free version, too: my bad for not linking to it. You can see from the screenshots that the battery percentage is on the lock screen and that it can be expanded to show you whatever information you set up to see. I'm not sure if you can do both things with the free version, but you definitely can with the pro.Ok does that definitely work on Android 5 lock screen? I'll have to see if I can find some screenies before I buy. All others I've tried work when unlocked but not on the lock screen
