Lock screen burn in
If you're concerned about burn in, you can create a black photo and use it as the screen saver. The phone will only use screensaver mode when it's plugged in. You may have to create a folder to place that one black image in otherwise, it will cycle through all the photos in the camera folder. It's a workaround but it should work until Samsung decides to give us the option to disable it.
If you look at the screen closely when AOD is up, everything moves slightly to avoid burn. This includes the FPS graphic and the charging message above. Nothing is stationary, it moves after a a bunch of seconds. Stare at it for a little bit and you'll see.
FahadsTech
