Lock Screen Widgets in Note 3 Missing?
Widgetlocker was updated last week to support the note3. The previous version that I restored from my note 2 had a overlay issue but now that's fixed as well. With this and Nils, I have lock screen notifications while keeping my lock pattern in tact... You can also add whatever widget the you want to the lock screen but its $3 or $4...
This would be nice!
Another thing that would be nice is if you had the option to disable the built-in notifications from SMS and Missed Calls from showing up on the lockscreen. That way those features could actually make sense when using dashclock. :)
You don't have to have your text messages show up on your lockscreen... that's just an option.
When using dashclock with the SMS extension set, when you receive an SMS the built-in ones automatically override the dashclock ones and push dashclock over one screen. So you would have the built-in ones on the main lockscreen page plus dashclock would pick it up.
Does this Notification setting help?
I read about better security feature being introduced in KitKat for lock screen widgets. Does anyone here have hands on experience?
I have widget locker on my note 3, im using it because id like my widget on my lock screen, the problem is when i clear the ram, widget locker is stopped, i want widget locker as default lockscreen, like my note 2...
Hi everyone.
I have a Samsung Galaxy S3 and I recently updated Android for 4.3 version
I was surprised by the way the lock screen has changed.
My issue with the way it's done now doesn't really rely on the number of widgets you can put on the lockscreen (but it's not cool anyway).
But what has changed from the previous version was: even though you have a security measure to access the phone (unlock it), it was necessary to swipe the screen first. Only after that your "favourite" security option would show up (pattern, pin, password). I think the current design is horrible, as the pin-pad or dot's to draw pattern are there as soon as you hit the Home button.
Just as and example, if I have PIN as security measure, I will have a pin-pad over my lock screen picture, even though I just want to check the time. It's visually bad.
Same thing for SMS. Even if you disable to show the message on lock screen, it will pop-up a rectangular white box saying "New message" (twice on the same box btw). Another visual blunder.
It was waaay better on the previous version when a small, transparent circle would show a number (of how many unread messages) and an small envelope (or a phone, in case was a missed call).
How can they possibly think the current way looks better?!
Disappointed :/
i could not find the multiple widgets options inside lock screen option in my device....so if u have got an idea then can u please share
GeekGlasses67
