Losing display when restarting phone!!! Help!!!
jmorgan3475
10
After I flash a ROM successfully and have it running for a bit, if I try to restart my phone normally when it turns back on it has a completely empty home screen. This has happened with several ROMs now such as several versions of KingsRom and the most recent is Warm TwoPointTwo. I use Titanium Backup to restore all my files from before, is there something I'm doing wrong because it doesn't seem like many other people have this problem.
Any help is appreciated, thanks.
Are you wiping everything 3xs? Before any flashing wipe 3xs on each cache, dalvik, data, system, boot, and battery stats! Leave all others alone. See if that helps
Sent from Looney Tunes Central!
theantithesis
