Loud buzzing noise while on a call
jcdub
371
23
18
Anytime else on here having an issue with a buzzing noise while on the phone? It lasts about 10 seconds and is quite loud. Then it stops. And comes back after a short while. Only started having the issue this week. I tried Google phone beta. But I'm having the same issue
I just started getting this after the latest March update. When it happened, I pulled the phone away and turned on speakerphone and then back to the earpiece and it went away.
Maybe it has something to do with me being on WiFi calling and something in the latest update?
I had it while using both the mobile network and WiFi calling. It's only since the latest beta 4 update
I just tested it and for me nothing so far. I'm running the June feature drop beta build which does have the march update.
I encountered the same issue after I updated to Beta. I had to reflash the feb stable firm to get rid of it. Beta opting out is currently a mess.
This just happened a moment ago. I was on a call and after about 15 minutes I heard a loud buzzing sound. I could not hear my daughter nor could she hear me. She also did not hear the buzzing sound that I heard. She uses an iPhone 12 Pro. The sound continued so after about 15 seconds I ended the call. I called her back and we spoke for another 15 minutes and everything was fine. This is the first time that it's happened to me. I'm on the Android 12L beta using a P6P.
I just updated to March play update last night and I've had no buzzing on any of my calls today this far. Fingers crossed that was the fix
EDIT: Just happened again on a call again. I can't deal with this. Other bugs ok, but if my job depends on a phone being able to do it's most primitive objective and it can't do that, it's worthless.
Jayarealways
