Loudspeaker defaulted when taking and making calls (new galaxy s6 )-please help!!!!!
Thank you @jc99be, your solution worked for me like a charm. But I still don't remember when did I changed the Samsung Internet app settings but nevertheless the trick worked.
In my case, the problem started a few days ago. I don't have a call recorder app installed.
I booted in safe mode and the problem was gone, so it had to be linked to one of my apps.
Started going through my apps via the application manager to see which ones had access to audio settings.
Surpringly, I saw that the "Samsung Internet" app accesses audio settings and I remembered that it was recently updated.
Went into the app, but didn't see any settings related to audio.
Finally, i tapped clear cache for the Samsung Internet app and that seemed to do the trick! Problem solved! Very strange!?!
Where i can go for clear the catche setting....
Apps drawer/Settings/Application manager, choose the Internet app, scroll down a bit and the "Clear Cache button is there.
Help is coming ...
If You have downloaded any of the voice recorder go to settings and turn off "auto speaker" ... That's it.
You welcome. :)
Re: Loudspfeaker defaulted when taking and making calls (new galaxy s6 )-please help!!!!!
Help is coming ...
You welcome. :)
I am having this issue with my s6 and i dont have a voice recording app on my phone. Any other suggestions other then resetting?
Laura Marriot,
My Alcatel Raven phone developed the same problem, but I did not really notice at what point it started. When I read your list of apps, I noticed we had only one in common: Call Recorder, by lovekara.
If this is the call recorder app you are using, try this fix:
Under the Settings menu, the third item down is auto speaker. Just turn this off.
Hope this helps.
Pst Ajode
