Low Audio Volume
Elzar
17
Hello - When I connect my Pixel 6 to my car via a USB to Aux cable, the volume is really low. I have to turn the volume on my car to the loudest setting to be able to hear it. When I connect with my Bluetooth headphone, the volume is normal. Is there some way I can boost the volume when I'm using the USB-C to Aux cable? Thanks for any help.
When you connect via Aux, make sure the volume on the phone is turned up high as well. Does that make a difference?
Just to piggy back on what @B. Diddy said. I'm pretty sure the volume setting doesn't carry from one Bluetooth device to another. It keeps them separate. For instance, my phone connects to my car and changes to max volume but when it connects to my earbuds it's only about 30%. It's 0% when not connected to anything
LilmissSunshine
