M Logo Replacement Area
Thanks for making these...... A Superuser one would be cool. I have a few in my wallpaper thread if you need a good image. Links under my signature.
Awesome idea! I was looking for a su icon that was good looking. Ill take a look at yours and make it happen. Thanks!
Sent from my DROIDX using Tapatalk
Super User M Logo Replacement - Thanks to Cyber Warrior for the image. Check his wallpapers in his sig and if you want one as a M logo let me know.
MEGAUPLOAD - The leading online storage and file delivery service
Reactions: Cyber Warrior
i will take it one step further.....
TNT can you please make this one....
THANKS TO CYBER for the image...
Using bootstrap. Says bad file or it gets stuck right off the bat and I have to pull the battery
I add the .bin file to logoreplacer.zip and use bootstrap to install zip from SD
Are u using 7zip to drop the new logo.bin file. I make the image to correct size and flip. Then run it in a hex editor and flip it back and delete some code to size it correctly and save as logo.bin. then open the logoreplacer zip with 7zip and drop the new logo in. Close and save. Drop on SD card boot recovery and install. I now use the boot logo replacement app. Just create the bin file and drop into app folder and select in app. Very easy.
Too much was deleted in hex or the outline in the photo has white. Ill try to get it done. Or make a black image 480x182 and make your image a few smaller like 478x180 and drop in center.
suuu
