M Logo Replacement Area
How this? Ill throw together the zip if you want it.
Could you throw a skull together for a boot logo? If you need me to supply a pic. Let me know
Just dl'd the file. Thank you very much. Im gonna give it a shot. How do you go about doing this? Not getting the images to replace the M logo. Im talkin about how to create these files fir use
Ok u will need a few programs like photoshop, 7zip and a hex editor like fehed. You will make a photo 480x182. Flip the photo so its backwards. Save as bmp 24 bit. Open with hex and flip the bytes. Delete the first two bytes then delete the last bunch so the end file size is 262080. Now save as logo.bin. now using 7zip open the logoreplacement zip from me. You will see the logo.bin file. Just select the new one u just made and drop into the zip and it will replace. X out and it will save. Drop the zip on sd card and do what you did to get this one on. It's some work but you will pick up quickly.
Sent from my DROIDX using Tapatalk
Reactions: racinwarrior
Would you mind to do an Autobot Logo to match the Decepticon?
An Autobot logo would be awesome. Also if you do the attached on a black background I would be eternally grateful. Thanks!
I will try and have this in a zip tomorrow night. Wont be home till then but I got you covered!
can you add the xmas android guy from the top of the forums? (i'm in the holiday mood) :)
Just finished my first theme for apex. I will try and get this done tomorrow for you. Need some sleep :)
Sent from my DROIDX
Yeah. Just the logo. I thought it would look kind of cool. If you can make it roughly half the size of the screen. Thanks again.
Taylor Bag
