Made a few booboos, need some help with TWRP
jackadillo
16
I wasn't able to properly root my Nexus 4 while using this guide. I wound up idiotically formatting the wrong part of my phone, so now my phone lacks an OS.
Is there any way I can access my phone via USB? I'd like to install a stock ROM and start over clean!
You can still recover it by flashing factory images onto the phone.
Get those from here: https://developers.google.com/android/nexus/images
Sent from my Galaxy S4 running SlimKat 4.4.2
Can't even mount from recovery to access my phone via USB. Had to go here:
Nexus Root Toolkit v1.8.0 | WugFresh
Hoping it works. Downloading the factory image via the toolkit.
- - - Updated - - -
After downloading the factory image follow this guide: http://forums.androidcentral.com/showthread.php?t=223923
Guide definitely looks legit, but I'm a bit unnerved by the OP there not giving specific directories to follow.
- - - Updated - - -
Wug's toolkit will work if you had USB debugging on or can get into fastboot
The OP in the guide is a former ambassador here. Definitely legit :)
Thanks for the guide. The toolkit I linked fixed everything, got me rooted, and has allowed me to flash slimkat.
mistan
