Anyone want to try 1.38? It has all the fixes. Specifically, people who have had issues.
push it to market. I wil l give it a try.
Just downloaded the latest version and testing it out. Why is MD showing 2 copies of an email when I sent a test email from either Gmail, Hotmail, etc. to the yahoo account on MD? However, if I send an email from my hosting account email it is fine. Any ideas how to fix this?
Also I'm not getting no notifications whether I choose "Let Device Sleep" or "Wake Up Every 15 minutes". It worked a few minutes initially, but nothing now. The notification will trigger when I unlock the screen and go to the application and hit Refresh, otherwise I get no notification. I was hoping that the notification thing was fixed in this release because it's frustrating having to go into the app every time to see if new email is there.
One question though....does the background data sync needs to be checked on my phone in order to get the email notifications?
Any plans to allow attachment of any sort of file to an email from the phone memory or SD card? Right now when I click the attach option I only get like gallery, music player, etc. and don't get any option to select a file from any folder.
Yes "reply to" flag would be a nice addition.
I having a problem after the app has been running for awhile. It acts like it quits talking to the server. I can't delete anything not refresh mail. a reboot allows it to work again for a little while.
I do not think I'm doing anything different, but not sure.
1.38 should fix it...had some connection code commented by mistake, 'doh. Luckily (kind of odd actually), that code path was not called all the time.
1. Bug, fixed in 1.38. It will be released in the morning or you can request an early copy now
2. Fixed in 1.38, I believe
3. Not sure I understand
4. Download OI file manager or astro and you can attach from anywhere you like
5. I have flags on my list to add
Maildroiddev,
One more bug as I have seen is that anything left in a pop3 inbox even though it has been downloaded via my computer, will not delete off of Maildroid. Do I have to go into settings and delete off my device?? Will there be an option to delete off both server and device as well as a choice to just delete it off the hand held?? Would it be possible to add this feature instead of one or the other?
Thank you,
Charlie
Just updated to 1.38, but having duplicate email issue still. I keep deleting an email and it pops back in the inbox again and when I delete it a second time it comes back again with 2 copies. Anyone else having same issue?
You may want to remove and re-create the account. I just tried this and it seemed fine for both pop and imap with both options delete from phone or both.
Wait until the next version. Sorry guys, I did not mean for the market to be my test ground and I really had many testers and I did a lot of testing. However, you can't account for everything. There are some delete sync issues right now that I am working on.
@Dirt When this happens, do you see any little progress circle in the top right corner?
