Market problem
Eric16
83
Ok well I prefer the old market, I liked going into like the sports category and picking the "just in" tab which gave u obviously new apps and as well as updated. With this market it dont have that but also idk if Im missing something thats obvious. If I search for example music player it says 3207 results but I can only see about 20. Same with the Lakers if I search Lakers it gives me a small amount but on my wifes 3D she still has the old market she gets alot more results.
Eric16,
When you have your search results, you should just have to scroll to the bottom and more will load. If it is right after you search, you will only see a few and need to click "Show More Apps" since it will return Apps, Games, Books, Movies. I'm not a huge fan of the new market either, but most of the time I just look for the exact app I want to download so it doesn't impact me as much.
Its kind of a pain but cool too. From the main menu click Apps. On top it says featured. You can slide it over to Categories then scroll down till you get to sports and then just slide from screen to screen to look at apps. But i just type what i am looking for and take it from their....
What i don't like about like about the new market is the widget. It doesn't open up to the main menu. I hate opening up into an App.
Eric16,
I dont have the "show more apps". For example like I said I search Lakers Im doing it now it says APPS 592 results then it shows 2 apps then Movies has 1 result then books has 563. Well I click on apps obviously then I will scroll to the bottom there is 16 apps. If I keep scrolling it does nothing it has no show more apps or nothing. When Im in the apps section where it only has 16 apps but says 592 results it has the triangle symbol that you can select market, apps, books, movies and when I click on it "APPS" is highlighted
Eric16, that is very odd. Usually when I scroll to the bottom (and go a little too far) it will just populate more apps. There isnt a button for more or anything I click, I just continue scrolling down.
OK Eric i see what your saying. I did the same thing for the Nicks and it game me the same results. When i typed in AndroidCentral it shows 303 but not all of them are AndroidCentral , Twitter came out too. Unless its just showing you what is just in the Lakers category . This is weird lol When i go into Apps. Category, music & slide over to top paid and top free it gives me a lot more apps
Ya idk if this newer market is different with the search options. I downloaded the newer market 3 different times on my 3D and kept deleting it I couldnt do it ha. But like before say you were to search Lakers, ESPN whatever it would give you hundreds of results, which some of them didnt have anything to do with what you searched sometimes it was just in the description of things so it would be listed under you searched if that makes sense. Maybe this market narrows it down where its just in the Title of the app.
Falsey_Ga
