Marshmallow bugs and/or missing options
Yup, my S6 has rebooted 7 times today, and it's not even noon yet. Please someone tell me I can undo this upgrade!!!!!
Well Verizon finally got Marshmallow, and I've noticed a few things that are broken or seem missing and I was wondering if anyone else was having these issues.
Quick Settings only allowing 8 icons despite you choosing 9 icons.
Lock screen doesn't show weather widget anymore.
When in battery options, the percentage left is no longer on the graph or on the page at all.
Battery percentage always showing in top corner of lock screen, no option to turn it off.
Swiping apps off of recent app screen is randomly unresponsive to swipes.
On the Lock Screen issue and weather widget no longer available for the Lock Screen. Has anyone found a solution to have the weather back on the lock screen?
I loved this S6 right up until Marshmallow updated/downgraded. Battery use is staggering now, and it wasn't stellar to begin with, but now my apps are being screwed with. If I'm on Iheart radio and turn on chrome or almost any other app, Iheart shuts down. The phone reboots on a whim now, and ALL apps are slow to respond, some won't start at all.
Is there a way to uninstall this "upgrade"?
This is exactly my experience! And I'm losing 20% battery an hour, sometimes more. I had to get a Mophie case to have any kind of functionality during the day because I can't be tethered to a charger all the time. Loved all my Galaxies up until now.
My battery saver option doesnt work anymore..
Update, it works. When its on Emmediate mode.
has anyone experienced the phone lock on power button not working? If I press the power button screen goes black and I can unlock it immediately.
I also have lockout on timeout set to immediate and same thing.
Have Verizon Galaxy S6 and the email notification isn't working right. Also, having problems with syncing. Have set to every 15 min but it won't sync unless you open the app. Notification light doesn't always work. Also have to swipe twice to access my phone, 1st to get to my swipe screen then my swipe. Anyone else with the same problem???
parsonsphil
Yep I got a cat s60 same problem
FahadsTech
