[MEGATHREAD] Voice command has stopped working
  • Start date Start date
A
AC Question
How do I fix "Unfortunately, voice command has stopped," message?
how can i fix it? i cant use my phone because it pops up always even i click its option "ok"
Re: Unfortunately, voice command has stopped
Not a Huawei as it was mentionned on Ebay but a Hongyue_W106_V43-3G-P20_pro_20181
Android 6.0
A-ha! So this sounds like a Huawei knockoff/clone phone, like you can find on various sites like Wish and Joom. All bets are off with these generally terrible devices. You can't trust anything they say in their advertisements because they lie through their teeth, and even the devices are programmed to fool a lot of benchmark apps into thinking their specs are higher than they really are. Check out Smoorez's YouTube channel -- he likes to get cheap knockoff phones and show what they're really running. Here's one where he reviews another "P20 Pro":
https://www.youtube.com/watch?v=07ox5eKi_WI
when i switch on my phone become stucked on voice command has stopped working
i can not acces my phone anymore
Re: when i switch on my phone become stucked on voice command has stopped working
Welcome to Android Central. To reply to this thread and receive notifications when others leave comments please register an account. This link will help you do that... https://forums.androidcentral.com/ask-question/409154-join-android-central-community-new-post.html
What phone do you have?
Do you have a lock pattern set, if you swipe from the bottom what option does it give you? Usually swiping from the bottom even when using fingerprint the option appears to enter a swipe pattern.
Tengo un Samsung galaxi C7 ....pero lose por el bootlogo la parte de atras no dice el modelo no dice nada.
Bueno y como todo samsung debería tener el menu donwload pero solo me envia directamente al menu recovery, queria cambiarle de finware de seguro en un celular chino que le pusieron el sistema de samsung c7....antes funcionaba normal pero por una actualizacion me empezo a aparecer ese error...yo queria reinstalar el sistema...pero no me permite hacer nada...algun dato?
psdt:Lo flashe y sigue igual.
I have a Samsung galaxi C7 .... but lose from the bootlogo the back does not say the model does not say anything.
Well, like all Samsung should have the donwload menu but it only sends me directly to the recovery menu, I wanted to change the insurance finware on a Chinese cell phone that they put the samsung c7 system ... before it worked normal but for an update it started me to appear that error ... I wanted to reinstall the system ... but it does not allow me to do anything ... any data?
psdt: I flash it and it remains the same.
Re: Cannot get past the 'Unfortunately, voice commands has stopped' .
Bienvenido a Android Central. Por lo que dices parece que el teléfono no es un Samsung original sino un clone que le pusieron una rom por encima. Me temo que el modo download de Samsung no va a poder funcionar. Ni idea de cuál puede ser el procedimiento para que vuelva a funcionar correctamente. Lo siento.
Cannot on my phone only showing unfortunately voice command stopped
Can't on phone showing unfortunately voice command stopped
I reboot the phone but still it's still popping up on my screen the voice command has stopped
It's a tečno y4 phone am trying to get past the voice command but can't go thro
My phone (infinix) voice command has stopped,what should I do?
I can't operate my phone, it's blank and only displays "unfortunately voice command has stopped.
hello how can i fix samsung android always flashing voice command has stopped
pls help,how can i fix my samsung android it always flashing unfortunately voice command has stopped,ive already the same
Re: hello how can i fix samsung android always flashing voice command has stopped
Is it a genuine Samsung, or fake?
Re: My phone (infinix) voice command has stopped,what should I do?
Google voice command? Try resetting the Google app by long pressing it then tap info scroll to storage and clear data/cache then force stop.
Try restarting the phone. If that doesn't fix it, Then let us know what changes you've made recently. One of them is probably stopping something from working. Also, what make and model is the phone? (You could try Safe Mode, but getting into Safe Mode can be different, depending on the phone.)
Adekanmbi
