[MEGATHREAD] What is google activity com.samsung.sdm.sdmviewer
flynnnmoe
List of terminology? Description? Samsung.sdm.sdmviewer???
In my "activity" there is always some items I don't understand. What is Samsung.sdm.sdmviewer? Android,server.telecom, then theres a couple others I can't think of off the top of my head. Trying to decifer some of these terms so I'd appreciate any help you can give.
Re: Is com.samsung.sdm.sdmviewer a voip? Will the calls show on my Verizon bill from sdm viewer? Tha
Welcome to Android Central! For the kind of detailed answer you're looking for, you'd probably have to ask a Samsung engineer. All we can tell you is that it's a legitimate Samsung system app, and there's nothing nefarious going on here.
Sdmviewer keeps popping up. I don't have a deskphone!
I keep find sdmviewer on my phone for Google activity. I don't have a deskphone. Noone else uses my Google account. Why does this keep popping up? Could it be system updates? Please someone shed some light here.
Re: List of terminology? Description? Samsung.sdm.sdmviewer???
YOU. ARE. AMAZING.
Incredibly interpreted. Easily comprehended. Pure Gold.
Thank you, good Sir. ((tipping hat))
That's the package name for Samsung Deskphone Manager. Android apps use a package name as a unique identifier. Each app must have a unique one so that you don't install one app in or over another. The package name is also part of the app's URL for the play store. This is yet another reason why an app's package name must be unique. When you install an app, whether it be from the play store, third-party market, or straight from an APK, an app package is downloaded (or loaded) and then installed from the app's APK. The APK contains the resources and dalvik code for the app. The package name in the APK becomes the installation directory and will also create a copy of the app's APK within the installation path. An APK is akin to a Win32 ".exe" executable, but acts as an installation package at the same time. They're essentially a ZIP archive that houses the app's compiled code/resources that are used when the app is launched. Here is an example of how the package name works in correlation with the APK:
/data/data/%DEVELOPER%.%APPNAME%/-1%APKNAME%.apk
"%DEVELOPER%.%APPNAME%" would be the app package name; developers sometimes place their name or the company's name, followed by the app name. Since namespaces are disallowed in package names, individual aspects of the package name are separated by decimals. I have found through my many modding ventures, that most package names begin with "com.". This is likely the result of an SDK automatically applying a package name from its own format or template package name that slaps-on the app name when the app is compiled.
Some apps even have multiple activities that will each have a "sub-package name" that carry out specific functions within the app. They look like something along these lines:
%DEV%.%APP%:
->%DEV%.%APP%.%ACTIVITY01%
-->%DEV%.%APP%.%ACTIVITY02%
--->%DEV%.%APP%.%ACTIVITY03%
These sub-activities function like entry points, and are essentially the same thing.
I suppose when it comes down to it, the package names and activities are decided by the developer and will vary per app. Often times parts of these names are abbreviations of things like the company or specific function. Some of these names can even be inferred as to what they are, or even do, based on the given names or labels they have.
Hope this helps.
Why does com.samsung.sdm.sdmviewer show up in my activity
This com.samsung.sdm.sdmviewer show up in my activity
Re: Why does com.samsung.sdm.sdmviewer show up in my activity
I smell another Megathread brewing ... ;)
EDIT: ... and done, and stickied.
tech gropse
