[MEGATHREAD] What is incall UI?
  • Thread starter Thread starter Andres
  • Start date Start date
Re: I know my boyfriend keeps hacking my phone
Honestly I'm not so sure that it is the boyfriend... I mean Lilmamag1123 claims that there are apps and web pages that cannot be accessed... That doesn't sound like typical spying methods and a hack sophisticated enough to prevent selective apps from opening or being used and preventing selective web access. That's NSA level stuff right there. At that level of sophistication there's no stopping him, actually we're all probably being spied on right now for even attempting to help her. Jealousy usually results in attempts to see who is being talked to, gathering intel on messages and images being shared. I think she may suffer from guilty conscience and/or an accusational boy friend and a buggy device.
Given that all use returns for a short while after factory reset I'd say your issue is an app that you keep reinstalling every time your reset your device. Maybe try to reset your device and disable "restore apps". Use the device vanilla, without any downloaded apps, for awhile and see if you have issues. Then add your apps back slowly until your issues return to try and figure out which app is causing you the issue. About now someone would suggest that you try the device in "Safe Mode" for awhile. You could try this before resetting but with no clear symptoms, I mean you problems are all over the place, it will still make finding the problem app difficult.
When restoring apps avoid Spam detectors, antivirus apps, battery booster apps, memory booster apps and anything else that is supposed to protect you from the big bad wolf or increase your devices performance. These types of apps usually cause more harm than good and frankly they usually don't work and cause issues like the ones you've described.
https://forums.androidcentral.com/ask-question/966023-i-ve-been-hacked-new-post.html
How do I find out WHO installed the Incalagent 313 spy app on my LG fortune cell phone?
How can I find out WHO put the Incalagent 313 app in my system on my LG fortune2 cell phone
Re: How do I find out WHO installed the Incalagent 313 spy app on my LG fortune cell phone?
Hi, welcome !
Nothing to be alarmed about its lg in call app
Welcome to Android Central.
It's not spyware. It's an LG system app that manages phone calls.
Welcome to Android Central! Why do you automatically assume it's spyware?
Many people automatically assume that anything without a name they recognize is spyware. (Why do you think we get so many questions about com.android.<whatever>?)
Yeah, just wondering if there's some other particular reason that could be explained easily by something else (like people knowing where the OP is at all times, because they might habitually check in or post where they are on social media.
What is com.samsung.android.incallui for
What is is for: Providing a user interface (ui) between the telephone function of the phone and the user.
What it does: Makes it possible for the user to make telephone calls.
Re: What is com.samsung.android.incallui for
That's the screen (UI) you see when you're in a call. It shows who you're talking to, and gives you options like ending the call, turning on the speaker, showing the dialer, etc.
If your seeing this in your Google activities, this your Samsung phone app , nothing to worry about as we get asked this question a lot here.
If you have futher questions ,I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
https://forums.androidcentral.com/showthread.php?t=409154
Me and the husband was wondering why it was showing up in his activity log
Yes he knows, he gave me his password freely but dont know what the com.android.callui is or what it does
Re: Me and the husband was wondering why it was showing up in his activity log
I agree nothing worry about, we get this question asked a lot about google activities
What is android.stk in ggogle activity . I keep.seeingnin husband mobile
What is mean android.stk.. I keep seeing my husband mobile...
What is android. In call ingoogle activity
Re: What is android.stk in ggogle activity . I keep.seeingnin husband mobile
For what it's worth, "STK" means SIM Tool Kit, and InCallUI means the In Call User Interface (i.e., how the phone screen look during a call). Totally normal. If you have concerns about your relationship, best to talk about them directly rather than snooping around.
Please enlighten me
My boyfriend’s google activity consistently shows com.android.incallui, com.android.mms, com.android.contacts in consecutive manner. Almost the same time stamps.
Is he trying to make a call or is he receiving a call?
Used com.Samsung.Android.dialer” And incallui
Okay, community. Need some help here. In my Google activity, “Used com.Samsung.Android.dialer” and “used com.Samsung.android incallui” comes up frequently, but it does not correspond with my carrier bill. I do have a Google voice number, and make calls on it. Is this what I’m seeing? Any help would be appreciated!
Michael Carvalho
