[MEGATHREAD] What is incall UI?
  • Thread starter Thread starter Andres
  • Start date Start date
Re: what is com.android.incallui mean????
Welcome to Android Central! It's InCallUI, meaning it's the user interface when you're in a call. So I think it manages how the screen behaves during a call.
est il possible d'installer incallui a distance ?
jai trouve cette application dans un cell je me demande si cest une forme de piratage ou si c est un installation deliberer...merci de repondre
Re: What is incalliu
Welcome to Android Central! It's InCallUI, and it's the User Interface for while you're in a call. It's a system app--don't mess with it.
Hi, i really want to know about incallui apk.
Is this app. Need to be installer or it can be allready install in a new phone. I find out this app un my phone and i dont know where it Come from . is it possible to someone to install it from distance. Thanks very much to respond me im very worry.
Re: Hi, i really want to know about incallui apk.
Welcome to Android Central! InCallUI is a system app--it's responsible for the User Interface while In a Call. Don't worry about it.:)
I want to uninstall incalliu from my Samsung Galaxy Trend NEO phone
I think it might be the cause of my battery being absolutely consumed. I have very few apps on my phone. I didn't install it, so want to ensure it's safe to remove
Re: I want to uninstall incalliu from my Samsung Galaxy Trend NEO phone
Welcome to Android Central! InCallUI is a system app. It is responsible for the user interface while you're in a call. You'd have to root in order to remove a system app, but this isn't one you want to remove.
Show us some battery stats so we can help you figure out the reason for the drain. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/am...ide-how-post-screenshots-android-central.html
Re: What is com.callui?
Welcome to Android Central! What search history are you talking about? Is it InCallUI? InCallUI is a system app or service that is responsible for the UI while you're in a call.
What is the app incallui used for on my andriod. And did it come with the phone or was it installed
Was in factory set or manually set
Re: What is LGE.incallui?
Welcome to Android Central! It's a system app that controls the user interface while you're in a call. Leave it alone--it's normal.
Welcome to Android Central! It's most likely LG's version of InCallUI, which is the system's way of handling the interface while you're in a call. Leave it alone.
Damn Dreya
