Memory issues post 2.1 flash
williest311
Active member
Apr 15, 2010
40
When I flashed 2.1 I saw that the internal memory was at 99.something. After downloading all my apps (17 of them). I am hovering around 47mb (cleared internet cache and everything). Most of my apps aren't that large so I'm trying to figure out why my memory is so low now.
What was the memory of most people after they flashed 2.1?? Is it normal for mine to be as low as it is now??
Any help would be appreciated.
I have the damage control 2.07 Rom flashed on my phone and 16 apps installed and I have around 84 mb have you tried using a task killer
Yeah I use a task killer....Are you talking about internal memory storage? I thought that the memory displayed in a task killer was different from storage memory??
I tried putting the link in but it doesn't work right its the option 2 under gbhill's post for Sprint 2.1 leak
I have an issue with option 3 and I'm running apps2sd. I had only used up 70MB right after flashing, and now its finally steady at 107MB
My phone also wasn't going to sleep very well. It doesn't sleep while it charges at all :/ and the battery life was horrible yesterday. I deleted some files I believe are problematic ones, and I'm testing it out. I can tell you even after removing them, it still doesn't sleep while on the charger.
Yeah I was talking about internal memory....and I use advanced task killer widget evertime you use it it says how much memory is remaining
SmoothieP
