MHS Battery Question
Bosgarage57
494
well, after the ICS update, my phone has been running very hot, wish I could go back to GB, but dont think I can, can I? I've noticed that when running Pandora, or MHS the battery drains even when plugged in. I do have the extended battery. I know both apps do use a lot of data, especially when pulling down 4g, but I am in good areas, so its not like it is searching too hard for a 4g signal. Any Suggestions?
I'm going to throw out two thoughts here.
1) You have too much running on your phone. The battery should charge your phone faster than the phone can drain it.
2) You have a bad battery...see above
Solution, either buy a new battery or try to get Verizon to replace it. Might not be easy with an extended unless you bought it from them.
kostopge
