Micro-SD card max GB compatibility?
bpfritzler
3
Looking for a definitive answer on this hopefully.
Samsung Tab3 8.0". What is the maximum capacity Micro-SD card that will work with this device?
I know Samsung says 32GB but I'm looking for real world experience here. I need to cache maps for offline use so would really prefer a 64GB card if it will work. Thanks in advance!
Page 14 of the manual for T310:
Memory Card
Your device supports removable microSD or microSDHC
memory cards with maximum capacities of 64 GB
(depending on the memory card manufacturer and type).
Memory cards are used to store music, photos, videos, and
other files.
Has anyone attempted to try the 128gb card? I have the Sprint version with a 64 gb, looking to double if at all possible.
I've been curious about a 128GB card as well as I also am using a 64GB SDXC memory card. In the spec sheet for my Tab 3 7.0", I'm not sure it it's a true limit or simply written at the time when there was no 128GB card on the market.
I lucked out with my MacBook Pro after a firmware update that I could upgrade to 16GB of RAM when the documentation reads that it has an 8GB limit.
In summary, I think it's possible as long as it's a SDXC memory card. Having the extra storage really makes my entry level tablet work much better with the current limits it already has. With the extra storage though, it's one awesome music player.
Jon OapostraphyBrien
