might be bricked and no custom recovery only default! help!
vtimmy13
hi i have an lg optimus v and i messed it up its in a boot loop where it just says lg and then virgin mobile or lg i never downloaded a custom recovery believe me i tried with rom manager clockwork wouldnt stay on! Anyways so ive been googling how to fix this i tried a kdz but it kept getting errors saying extract file erorr so then i saw this by cooper (scroll past to see rest of post
How to unbrick
With the influx of new people to rooting, I decided to write this guide. If you experiment or make mistakes sometimes something may go wrong with your phone. This will fix almost any problems. I like testing anything, and I've never permanently bricked. I've got caught in a bootloop, my phone wouldn't boot, and some other things. Custom recovery wouldn't boot or system was corrupted, among other things. This has fixed it all.
The only things this may not fix are if you flash the wrong .tar through SWUpgrade, and sometimes if you flash the wrong sized boot image.
**Note** If you are able to flash something through custom recovery, Just do step 2.
1. Flash this through SWUpgrade: Free File Hosting, Online Storage &amp File Upload with FileServe (installs 2.1 with custom recovery)
2. Put this in your SD card in sdx/zip. Flash it through the custom recovery (puts you to 2.1 stock) full_restore_stock.zip
3. Download this file and place it in the root of your SD card. Select apply update.zip in the stock recovery (get to it same way as custom recovery) update.zip - 4shared.com - online file sharing and storage - download (updates phone to Froyo)
4. Download this file and flash it through SWUpgrade: http://dl.dropbox.com/u/21183005/recovery.tar (adds custom recovery to 2.2)
well since i only have stock recovery and my device is froyo not 2.1 i see option 3 as my only choice if im wrong please correct me! but his link update.zip go to it it brings u to nothing just 4shared saying The file link that you requested is not valid. Please help. Any other ways btw i am really new to all this command stuff so please go easy on me! Also if i fo coopers method where do i put it on the stock like what folder where and how do i get it on my lg optimus v. Take someone elses phone put my sim in it. could it be a feature phone?
pcjordanellis
