Minimum Volume Level is wayyy too loud
checkmate
Active member
Dec 9, 2013
39
Does anyone else think the minimum Volume Level is too high since the Nougat upgrade?
I can't have sounds on at work now because the whole office can hear my almighty notification 'siren' on the lowest volume setting!
Ideally I'd like another 5 steps between minimum and off.
I wish the volume was a bit higher. Especially when using the speaker phone while driving.
I have the same thing. For me it is too low even while I am not in the car.
I think that's really a separate issue - at least with the max volume you can get a Bluetooth speaker or similar. With the minimum you're stuck with the phone's default setting.
DanishDanuu
