Missing hovering light trail on lockscreen
All,
This isn't important, however, I kinda miss having this functionality. When my phone was on its lock screen, I used to have the ability to hover my finger over my lock screen and a light would follow my finger. After receiving the latest update, this no longer happens. Just a preference, but I'd like to get this back again. Any suggestions?
J
Solved.
issue resolved by enabling following 3 steps.
1. Enable Air view
2. Enable unclock effects ( to any of which u like)
3. Remove pattern ( I was using pattern, u can try by disabling any lock u have applied )
It will work.
Plz note that I m using Xposed additions as well.
Hello i just got the galaxy s4 with the latest software, did factory reset etc 2 days straight i`m trying to set up that hovering light thing (saw it on a friend 2 years ago) Need more assist.
I have all the air things turned on etc, and did everything mentioned above.
Downloaded an App. called Galaxy Lock screen effects.. it has most amazing effects even better than Light effect ;-)
mersy78
