MIUIGb[WIP] 10-20-12
Status
Not open for further replies.
Re: MIUIGb[WIP] 9-2-12
Let me know how's its goes
wanna test roms and various android things?
follow me on Google+
jon gardikig
I have a android as a avatar
Here's what I got so far, I'll edit this post as I go.
-Camera is not reliable, I keep getting asked if I want to force close it. When the rom booted up, I took a couple pictures, quality isn't great then I tried again and it quit and won't work again. Keeps freezing then FC'ing. Camera working. Just needed a reboot. Something may have been interfering. May have been the FM radio.
-Not sure if Sound is working or not. I downloaded SoundAbout to reroute my headset, when I clicked for sound out of speaker only, I heard sound for a split second then stopped. Does that each time I click it. Sound is working. Just needed a reboot.
-The torch freezes up the phone. Set it down for a few minutes then torch finally force closed.
-MMS still not working i'm guessing.
Other than those, it works fine!
Cool Cole made me change sig well I've got 2 testers its all I need
Sent From An Optimus s
HI been using your lovely Rom for a day now.. couple of issues...Themes will not apply no matter what
Opening the MiuiFilemanager frequently causes FC's
Roaming Indicator shows up in notification area.....this can be fixed by editing the "eri.xml"
other than that looking good keep up the nice work
EDIT: Solved Theme not applying Issue...Create the folder "theme" in /data/system/
Do you have the first build from Gannon? 7-(so on)? I need to pull something from it.
Is this from the XDA thread? Or VMroms? (Last Question)
Also, so this isn't confusing, I'm looking for his last build on VMRoms.
Status
JasonReed
