MIUIGb[WIP] 10-20-12
Status
Not open for further replies.
Re: MIUIGb[WIP] 9-2-12
You can?t sync MIUI. No sources. ;)
your right.......
will do my best to fix mms as i do not know how to decompile a .jar file and recompile it
can anyone shed some light on this???
I really want to flash this but I guess ill wait until mms is fixed because I need it
Sent from my LG-VM670 using Xparent SkyBlue Tapatalk 2
Try this to fix cm settings
Flash the really old initial release from Gannon, then flash the rom without erasing anything....this fixed CM settings before.
Sent from my LG-LW690 using Tapatalk 2
All the lag is still there. And alot of things force close, you deleted the memory killer. Your also missing alot of libs,bin files, and etc files. Your porting wrong
Reactions: sellers86
Nothings fc's for me
Lag gone after removing flip clock
after every reboot you have to let phone sit there for a minute
But if it pleases I will try again
Lag is there. Quickpic doesnt work because your missing libs, Memory Killrr force closes.
I can confirm a lot of what tgl says. Quick pick doesn't work at all. Half of the settings force close. I had about 4 reboots and that was just under an hour
Sorry guys couldn't re port as I will attempt tomorrow I had a labor day BQ
Replacing apps media and framework will get it BOOTED, but no fully working.
As he came out with new build anyway will fix after school
Status
JasonReed
