Mobile data can't switch to other
  • Start date Start date
I had the same issue but now it has been resolved.Try this
Go to settings>>apps>>Scroll down to settings>>tap on storage>>tap on clear cache and clear data
Hope this helps because elsewhere the only solution posted was to perform a factory reset. I was saved.Phew!
Thanks Mr.Kushagra Gupta.. you saved my day :) it works a charm now.
Thank you for your suggestion. I have android 5.0.2 and when I try to do exactly that, the settings app close but the data is not erased. When I tap on erase cache, nothing happens. The problem is thus not resolved. Would you have an idea how to erase the data/cache in this case? Thanks in advance!
thanks a lot bro...registered only to say thanks to u my broo...
Thanks man kushagra it seriously works like miracle I'll try to do this from last 24 hrs but nothing happens but it works like hell thanks
Just signed to say, thanks
I was going to do factory reset.
It's so easy.
Also thanks for the video,
It help a lot,
To all who have not been able to solve the problem,
Just see the video once,
It's easy....
Thanks a lot bro
Pickle240
