Mobile data can't switch to other
  • Start date Start date
I had the same issue but now it has been resolved.Try this
Go to settings>>apps>>Scroll down to settings>>tap on storage>>tap on clear cache and clear data
Hope this helps because elsewhere the only solution posted was to perform a factory reset. I was saved.Phew!
Amazing!!! Thanks so much for this solution. I was fed up going to the Vodafone stores N number of times. Your solution was a life saver.Many Many thanks!!!
Hi Kushagra,
I couldn't find how to do this in my moto g3 turbo edition. Could you please explain again??
Thanks a lot
I am facing the same issue in Moto G3 Turbo Edition. I am not able to find this option either in Tuebo Edition.
Hi Kushagra Gupta! I registered in Android Central just to say "Thank you" for your simple solution!! I was considering doing a hard reset later this day and your simple solution did the trick!!! :D Thanks a lot!!! :)
Thanks alot bro. Js registered on this forum to say thanks to u. U hv really helped me n many struggling with d issue...
Keep on doin d gud work.
Wish u success in life👍
I have to this site thank u in comments
Thanks Mr. Kushagra Gupta2
this method clearly worked for me so thanks a lot
Thx a lot dude... problem solved
My Dear Kushagra Gupta2
I was facing same problem for couple of days and running from pillar to post to get it rectified. At last yesterday all on a sudden I found your solution and applied. The problem was instantly solved. I heaved a sigh of relief.
I extend my sincere thanks for sharing your knowledge with this platform.
Thanks once again.
Yours
Ashok Kumar Nandi
kctraci1
