Mobile data icon disappeared from notifications -
  • Start date Start date
A
AC Question
The mobiel data icon has suddenly gone from my notifications panel.
I haven't changed any settings. It was there one minute gone the next.
How do i get it back with my other icons?
I cannot see how to add it back on in settings.
Don't really want to reset the phone if possible.
Everyone I was experiencing the same problem. I think samsung realised it and put out the quick restore app in the galaxy app store. Once you download it and restore ur quick settings it asks you immediately to uninstall it. This works as I have all my quick settings icons again. Please try it if u have not yet done so. Thanks for the person who first posted this fix.
Go to Samsung apps store and download QuickPanel Restore then your notification panel will be restored and Mobile Data will be there. Hit "edit" on the notification panel and drag mobile data icon where you want.
Even i was having the same problem with my s6 edge in india..but now its solved..try this link and follow the posts...
[link removed by mod]
When you press on the tab next to the settings wheel, you'll see all your shortcut tabs...press the "pencil" tab at the top right & follow directions on how to move & drag
Good Day Guys
I had same issue with my galaxy Alpha (lollipop 5.0.2)
I went to settings. Notification panel setting. There is an RESET icon on the right side. Just i did it reset and the dissappeared icons came back.
You can try it as well.
Thanks
Hey friends m from india n i have solition of this..
go to menu , click galaxy apps (app store), search "QUICKPANEL RESTORE"
download it n by one click u got mobile data icon back..thanx
reply if it works..
Heyy guys all use need to do is install quick panel restore from galaxy apps then once it has installed open ot press restore and it will restore the quick options bar and it will not restore anything else in your phone and you get your mobile data icon plus some extras
this works 100% :go to youtube and watch the video called:
Samsung Galaxy S6 Edge: Bring Back Missing Mobile Data Toggle Button from Quick Access
sorry that I can`t post the direct link, I`m new here.
It workd perfeclty 4 my samsubg 5!!!
Well i do have a note 3 'at&t' lollipop 5.0. Data option from notification panel disappeared my brother owe Samsung galaxy s5, at&t lollipop, even he doesnt have an option. Wherease, my friend has an s4 with same at&t carrier even he doesnt have. But my uncle has an s4 too runing android kitkat from t-mobile, but he does have an option of data on notification panel. I think its either Touchwiz, carrier or lollipop problem. Im getting sick of this samsung devices.
Back up & reset your android phone.
I experienced the same thing & doing it would be the solution. I dont recomend this specially if you have important files saved.
But see I already had the icons back with a smile :)
HOPE THIS WILL HELP
you have tout installer an APK
W3.frandroid.com/marques/samsung/289657_galaxy-s6-s6-edge-licone-donnees-mobiles-disparait-magie
Even after a hard rest without backup doesn'the solve it I've find an APK on phantoms site and it works I'Ve not tested theQuickPanel Restore but it seems works in the comments of others peoplea. .
How i can get mobile data to my notification panel
Same here in india. I just bought new moto g3 n got shocked after realizing that shortcut switch/button for data on off was not in notification panel. Its really irreateting, every time i need to go settings, data section, turn on data switch manually.
Ashok Dharshan
