Mock location issue on S7 Edge
  • Start date Start date
A
AC Question
I have never installed any kind of fake GPS or app that spoofs location first off. This has been an issue seemingly out of nowhere. I have the app shopkick which uses your location to confirm you're in a store scanning items for points to use towards gift cards. I was using it just fine for a couple months and now it's not working and support claims I have some kind of mock location setting enabled.
I've done the whole developer thing and confirmed that 'no apps' is selected for the mock location but it still won't work. I do not understand. I've turned location off and then changed settings, uninstalled and reinstalled the app, etc. Nothing is working. Please help.
If you just upgraded to Android 7, the other app may need an upgrade to work properly for Android 7.
