Masterjakeway
- May 26, 2011
- 159
- 10
- 0
does 4.5 work with cm9? can't seem to get it to work...
It's discontinued. Let old hacks die.
Sent from my SPH-D710 using Android Central Forums
Why are so many hell bent on killing off threads in this forum now?It's discontinued. Let old hacks die.
Sorry, I do normally continue to provide support, I just missed the thread. Have been having a horrible month. Anyway.. What happens when you guys try to apply it and do you have your SD Card already partitioned with a EXT partition? I'm using 4.5.0 on CM9 and it works great.
ShadowEO, if we're using your previous 4.4.0 or 2.2.0 version, are there any special steps to switch over to the 4.5.0 XDA version? Do we need to start completely over or can we save the apps already on the sd-ext partition? Thanks.
