[MOD]Amphetamines! Inject your Optimus today!
Just making sure, I don't need to do a factory reset and clean install, I can just flash this in recovery?
Guys not to be short but this two answers can be found on the OP,
yes just flash it, no need to wipe anything
2nd it gives your phone a kick ;)
Reactions: jonny5449
Anyone else try this who uses link2sd? I got errors with mounting the sdext partition on boot while using this and MIUI which were fixed by having link2sd recreate mount scripts. I just wanted to see if this is something to watch out for if it is affecting others?
Seems to be fine now...
thanks...I installed this but my Operation mini browser had 1 force close in an hour. My phone seems faster and apps seem like they start up faster but it could be my imagination or not. thanks anyways.
I installed on my s and in 5 minutes my phone flies like a plane going a 800 miles an hour awesome thanks
Sent from futuristic optimus s
This by FAR exceeded my expectations. Flashed on my optimus V with backside rom and there is a very noticeable improvement. THANKS!!!
I would also like to add that since flashing this there have been no random reboots, and I'm at 725 oc.
Currently running BackSide and after adding this I notice a small improvement. :)
X2
little and nothing exciting( significantly) noticeable as far as speed. I guess different apps require more time( processing) to do they need to do the matter what.
Not putting this mod down by any means tho;)
I tried flashing this but for some reason the tweaks weren't sticking. I managed by unzipping and moving the files to the appropriate locations.
Mount /system before flashing?
installed with ease,boot improvement was noticeable on iho backside,also prep of sdcard was faster. things seem to react faster like menu prompts,etc. nice little package. :thumbup: thank you.
I installed it last night, it seems quicker but I wonder if any of that is placebo effect. Regardless, it didn't hurt the phone, and it didn't cost anything, so I give it a thumbs up. :cool:
Well I just installed the amphetamines mod myself, and the results were disappointing, unfortunately.
LG Optimus V
IHO BACKside ROM
Boot times
LG logo to Virgin Mobile, with mod: 60s
LG logo to Virgin Mobile, without mod: 59s
Didn't speed up my boot times, in fact it was a second slower
LG Optimus V
IHO BACKside ROM
Boot times
Maybe it didn't stick, try putting the files in the folders the other guy suggested?
Okay if you are running IHO this is not needed, but if you are running either Stock Rooted or Stock Custom then yes use. Note: because of the extra init.d folder scripts boot time well be slower.
I thought it was a great name. It was the main reason i tried it out. And, it seems to of helped a bit as well, especially for screen responsiveness.
Why not muscle, speed, Hercules, hero, Tap out, and a million others? Amphetamines? Really? Just think that is for tweaks.....known a few, they burn and die quick.
Don't boo things you can't use johnly.
Sent from my VM670 using Tapatalk 2
I know all to well friend.
It doesn't change the name of the kernel in my settings. But when I flashed, it completely flashed! So is the name in the about phone option in settings supposed to change?
Other than that's its awesome :thumbup:
that is because it is a script and not a kernel. It will not show in about phone.
from LG-LS670 w thekraven ICS/CM9 ROM & Tapatalk
Reactions: braxton355
kitlis
