[MOD] Collin_ph Battery Tweak
Well it appears my anxiety got the best of me... got to love insomnia. I realized i was below 30% battery the whole time and I rememberd that's what the function of the script is!
I did it for the lulz! =\ I need to sleep.
Sent from my LG-LS670 using Tapatalk
I am unable to set my minimum frequency? ? Only sets it higher when Charging if I unplug and reboot it goes down to 245
Alright, to address the issue we have to try to run the system at "bare minimums" to see if we can eliminate the issue. First, read my FAQ. Do the same process you have been trying to wipe, flash system-debug.zip and flash ROM then gapps. Now, try it without restoring the apps+data from TB. I know it's hard to swallow with certain apps, but for now try downloading the apps again straight from the market. Only use the ones that are a necessity. Also, don't flash apps2sd or battery tweak mod. See what results you get just running the ROM by itself. Then, we can add one thing at a time.
My guess is that it's the apps that you are restoring that are causing the issue. Try without everything. After a test run, flash the battery tweak mod first and see how that works for a day or two. Then go back to using apps2sd and so on and so forth. I would avoid restoring all the apps+data from TB at all.
EDIT: This is an appropriate thread IMO! :D
It would appear that I've found my battery life again. wiped everything, reinstalled CM7 and ran barebones for a day or so. typically getting home (after 12 hour work day) with 60% or so left. I started installing a couple of things back into the phone to keep an eye on them. I'm going to say I've got 40% of my apps reinstalled over the course of 2 weeks or so. For what it's worth, I did notice that fancy widgets pulled the battery down faster (despite turning off the update functionality) and gentle alarm kept the phone awake for 3 hours before I caught it and uninstalled. This is still without the battery tweak running, which I may give a shot again once i get everything where it should be.
Just install it on zvh update WORKS!!!!!!
806mhz is super quick
Only use the setting it has on the the tweak (use terminal emulater)since there are no.cpu setting like cm7 so dont use no widgets no app just the collins tweak.....
Ashok Dharshan
